LG Power Tracfone, ran on Android's 5.0 Lollipop platform with a 4.5" FWVGA Display, Model (L22C).
17 Questions View all
How to turn on USB Debugging (Power button broken, and phone off)
Hello. First of all, thank you for reading this.
My issue is that I want to turn on USB debugging so I can use ADB to turn on my phone, since my phone died and my phone's power button is broken. But, I cant use ADB since I didn't enable USB Debugging in the first place. Is there a way to turn on USB Debugging without using a power button and turning on my phone? This happened when I accidentally put my phone in a deep puddle. After that, my back panel got wet and then my power button wouldn't respond anymore.
Thanks for reading
Score 1
4 Comments
I hope there is a solution to fix this problem. I suffer from the same problem.
by
It trun on went back of
=== Update (03/02/2019) ===
Help me fix it
Don't know what to do
by
Yes it and don't working now
by
What can I do
by
Add a comment
Most Helpful Answer
There is a sort of last ditch effort to try and turn on the phone without the use of the power button but there is risk of damage to the phone. It requires disassembling the phone to get the power button soldering points and bypassing the power button with some wire. This will turn the phone on but at your own risk. If you decide to perform this option, you do so at your own risk. I am not liable for any damage that you cause to your phone.
Score 1
1 Comment:
I applied it yesterday and I solved the problem. There is no other choice to fix it but some phones can be turned on by shocking. If you want to use shocking, the battery must be removable. plug in the phone charger. after turn on the screen, remove charger and battery. then plug in the battery.
by
Add a comment
Hi, i’ve read your problems. But i’m sorry to tell you that there is no way. I hope you understand ):
Add a comment
Add your answer
Arai Natsuki will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 10
All Time: 2,045
