Model A1238 / 80, 120, or 160 GB hard drive / black or silver metal front
931 Questions View all
Dying battery replaced, now iPod won't turn on. What happened?
I have an 80gb ipod classic, and the battery wouldn't hold a charge for very long (like a couple of hours without using it at all). I got a new battery and followed the install manual to the letter (using the appropriate tools from ifixit). New battery, and after several hours of charging, no response from the ipod. Ok, pull the new battery and put the old one back in, still no response after charging over night.
When I plug the ipod in to my computer, I get an error that the "iPod software server could not be contacted. The server does not support this version of iTunes"
However, it's the latest version of itunes, and my ipod responded fine before (and I know I have an internet connection that iTunes can see due to other i-devices having no problem).
What happened?
Add a comment
Spread Fixmas Cheer
Get $12 off your purchase of $50 or more with code FIXMAS12
Spread Fixmas Cheer
1 Answer
Chosen Solution
gofargogo, the first thing I would look at is the small connector where the battery cable connects to. Make sure it is still properly on the logic board. I have had trouble with the connectors coming of the board. The second thing that you can try, is to charge the ipod on a wall charger and see if that makes a difference. Check your dock connector and make sure that there is no debris or corrosion present. and clean it with my favorite, isopropyl alcohol :-) Once you have that accomplished see what happens let us know. As for your itunes error try this neat little trick from Majesty on Cant restore. Itunes error "server does not support this version" Good Luck.
Score 1
Add a comment
Add your answer
gofargogo will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 12
All Time: 1,788
