The fifth-generation Volkswagen Jetta was introduced in January 2005.
28 Questions View all
Tire Pressure light is on, even though the tires are full of air
Out of my manual, the signal is on when i turn the car on, and it stays on meaning there is a malfunction in the system, no message pops up only the low pressure indicator.
Tires are as follow: 36 - 35.5 || 36 - 25
Tire recommended: 34 psi || Front + rear.
*Not sure if having a higher PSI will trigger a warning or not
  • Not sure if the car is checking the pressure in my spare tire or not
  • I DO NOT have a reset button in my glove box, keep in mind i have a 07 VW jetta.
  • i believe the person i bought my car from changed the tires to slightly larger ones, so i don't know if i need more or less PSI
so
*Does my 07 jetta check the spare?
  • is there a reset button some where on the older ( 07 ) models i don't know about?
  • i will lower the psi to the recommended 34 to see if that helps, and check my spare and will update this post afterwards
Add a comment
1 Answer
Does the indicator blink on and off before turning solidly on? If so you might have a fault with the TPMS system.
Add a comment
Add your answer
VenKazi Productions will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 11
All Time: 744
