Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
iPhone 6 & DSPS.
Hi Guys i have an DCPS W.E.R 853D.
When i connect iphone , after 3/4 minutes, iphone restart automatically.
I check the phone with Iphone battery , everything is well.
I try also with different cable but phone restart again.
The voltage on display remain 3,8
The current move from 0,4 to 0,9.
Any body have suggestion plz.
Thanks
1 Comment
Do I understand correctly that the phone works fine with a battery but not a DCPS?
by
Add a comment
Chosen Solution
Yes Mnho.. Right.. i found the problem.. The cable is fault.. i change it.. Thanks a lot :)
Add a comment
Most Helpful Answer
Most DCPS cables don’t have data lines only positive and negative so battery will clip after a min or so due to not recognizing a gas gauge or swi line that normally is connected with battey. You can read more about battey data on this site.
https://www.aonemobiles.com.au/2018/06/i...
Score 1
Add a comment
Add your answer
AGS will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 2
All Time: 59
