Mid 2012 model, A1278 / 2.5 GHz i5 or 2.9 GHz i7 processor.
1624 Questions View all
How to mount SSHD Seagate Firecuda, installed and does not mount
Hi guys,
The hard drive in my macbook pro failed, so I installed a new 2TB Seagate Firecuda, I also upgraded the RAM from 8 to 16GB. After I installed the hard drive, I installed the OS X, laptop restarted and I got the white screen with the flashing question mark folder. I restarted with the Cmd+R, in the Disk Utility it shows the new hard drive but it won't mount.
Help will be much appreciated.
Thanks!
Add a comment
1 Answer
Most Helpful Answer
What happens when you reboot and pass the Option key, Do you see the drive then?
Reference: Mac startup key combinations
Score 1
2 Comments:
the drive shows on the right side no problem, but it just won't mount
by
You'll need to reformat the drive, I suspect you didn't select the correct format. It needs to be GUID and journaled.
by
Add a comment
Add your answer
Inaki will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 272
