13" aluminum unibody, 2.0 or 2.4 GHz Core 2 Duo processor.
574 Questions View all
Why won't my MacBook Pro charge?
The charger light comes on periodically and charges but now it won't. I had to move it around and by luck it would get it just right to charge. Do the magnetic pins wear down in the charger or the laptop?
Score 1
Add a comment
Most Helpful Answer
It could be the pins on your charger if it it the original. I have the same issue with my older MacBook Pro(2009). You could try replacing the DC in board, or using a newer charger if it really bothers you.
Score 1
1 Comment:
Thank you for your reply. I tried a different charger and it works much better. I like the video and since it is an older laptop I will probably need the video in the near future.
by
Add a comment
the pins don't wear down, but the springs. as you have to move the coil around, it could also be a break in the cable itself, usually the plus cable. try a different charger, check for differences. post.
Score 1
1 Comment:
Thank you for your response. I changed power cords and it is working now. The old cord finally did not charge at all.
by
Add a comment
Add your answer
Peggy Ohms will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 8
All Time: 68
