element tv wont stay on, cuts on and off & changes channels
powers off after changing channels several times back to back then cuts itself back on within 5-7 minutes to do this all over again.
Update (07/28/2018)
oldturkey03, attached is a pic of the iR board from the bottom of the TV. Very little on it! the ir sensor, a resistor and a LED to indicate "on" or "standby" (red or blue). Let me know what you think! Thanks.
Update (07/28/2018)
Here is a photo of the main board. The IR sensor board is plugged into the main board at the bottom center connector, the 5 larger gray wires on the right side of the plug.
Update (07/29/2018)
Pic of the rear of my main board of a Element ELEFW408
2 Comments
This ain't helping me at all. My tv is doing the same thing. Don't know whats wrong with it. An element 40 inch. Model number ELEFW408
by Monet Carter
@Monet Carter ,
Just verifying that you tried the following one at a time:
removing the batteries from the TV remote control unit and also any other remote control unit in the room e.g. Firestick remote etc
disconnecting the IR board in the TV from the mainboard
the TV control button board from the mainboard
and it is still happening?
by jayeff
