The March 2015 update of Apple's 13" MacBook Pro Retina Display, model A1502, features fifth-generation Intel Core i5 and i7 processors and introduces the Force Touch trackpad.
1185 Questions View all
Why doesn't my keyboard work after replacing the display on my laptop?
I replaced my display. Following the instructions on ifixit. Prior to doing this the keyboard worked fine. Now 5,t,g, and b dont work as well as other keys at random times. The "e" key is sticking on. What could i have damaged? I only changed the display connections (wifi,camera, and display). Otherwise i disconnected the battery. Any ideas?
Update (05/31/2018)
From BeetsTech, it’s a refurbished display MacBook Pro retina A1502 Complete display assembly 13.3” Apple P/N 661-02360 (mf839, mf841, mf843)
Score 1
2 Comments:
What display did you put in part number and source?
by
BeetsTech offers a good product.
by
Add a comment
1 Answer
OK, thats the correct part.
It sounds like the iSight camera is messed up. Do you still have the old display assembly: if you do plug in the iSight cable from it. Did that fix the issue? If so you’ll need to get a replacement.
Update (07/15/2019)
Clearly the keyboard is also in trouble. Did you have a spill or did you get some solvent leaked into the keyboard damaging it if you also replaced the battery
1 Comment:
I tried this. It didn't change anything. The camera works fine on the new display. What else could it be?
by
Add a comment
Add your answer
Joel will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 73
