Repair guides and support for the laptop line of Acer's Aspire series for casual home and business use.
1190 Questions View all
My brand new laptop is working very slowly
Laptop version: Acer Aspire 5 a515-51g i7
Windows: 10
Anti Virus: Avast Premiere
My brand new laptop brought 2 months ago is working very slow.
Windows loading very slow, Photoshop very slow, and overall is working too slow considering the hardware settings of this laptop.
I have no idea why, I hope you all come with a solution.
Thank you!
Score 6
7 Comments
Has the computer always been slow, or did it slow down after you have had it for some time?
What is slow? Is it when you surf the web? Or is everything slow?
by
Hello, sorry for the late answer.
The laptop was slow from the very beginning. Everything seems to have a bit of "lag" frames.
Only within the windows, the web navigation is ok.
Especially in photoshop or when I m trying to open it, takes a lot of time to do so, and windows is opening slow.
by
Windows: 10
Anti Virus: Kaspersky
My brand new laptop brought 3 months ago is working very slow.
Windows loading very slow, It takes a long time to start after a reastart, and overall is working too slow considering the hardware settings of this laptop.
by
I have the same slowness problem so I have decided not to buy an Acer again.
by
I have Acer Aspire Notebook E13 that has a chronic slowness problem.
i.e. 15 minutes to log onto zoom.
by
Show 2 more comments
Add a comment
Chosen Solution
If your laptop is running more slowly than usual or has become increasingly slow over the past several weeks or months, see the Acer Aspire 5253 Is Running Slowly problem page for possible problems and solutions.
Do you install too many applications on your computer? Or do you enable lots of startup programs? If you enable too many startup programs on your computer, these programs will start themselves automatically when your computer boots, which will slow down the startup speed of your computer. My Acer Aspire computer also runs very slow. Maybe you can try the below several methods to fix this issue.
Method 1: Remove Virus or Malware in Your PC
Windows 10 is susceptible to viruses and other types of malicious software. Virus or malware do no huge damage to your system, but they will slowly slow down your computer. If you are running Windows 10, you can use Windows Defender to troubleshoot malware and other potentially unwanted software for your PC.
Method 2: Clean Up Hard Drive to Free More Space
If you seldom clean up your Acer laptop, too many junk files may be left on your computer. They will occupy large disk space on your drive and slow down your computer. To make your computer faster, you need to clean these junk files regularly. iSunshare System Genius is a good junk file cleaner and a system optimizer. Maybe you can have a try if you don’t know how to clear junk files.
Method 3: Disable Some Unwanted Startup Programs
Go to Task Manager > Startup and look for the program that you don't want it to start automatically, right-click it, and choose Disable.
Method 4: End the Processes of Unnecessary Apps
Go to Task Manager > Processes, right-click the target App, and then choose End Task.
Here is a link for you to get more information: https://www.isunshare.com/computer/solve...
Score 2
Add a comment
Hi. My name is Willian, and I brazilian. I speake portuguese.
Eu substitui o HD por um SSD M.2.
Após a substituição dos discos rígidos, fiz uma nova instalação do Windows 10 Home Edition.
Pronto! Problema resolvido!
Boa sorte!
Score 1
3 Comments:
Si puede poner la pregunta in espanol, es mas posible que alguien entendera.
Perdone que no entiendo el portugues.
by
I replace the HD with an M.2 SSD.
After replacing the hard drives, I did a new installation of Windows 10 Home Edition.
Ready! Problem solved!
Good luck!
by
I believe that both the SSD and the clean install solved the problem. The SSD made things operate faster; and the clean install cleaned out any junk that had collected in Windows and was slowing it down.
by
Add a comment
Run the system configuration
1 Comment:
Exactly! Buying a M.2 2280 SSD was an excellent investment I made in my laptop ACER ASPIRE A515-51G-58VH, as it made the performance increase many times. With the SSD M.2 2280, and with a new installation of Windows 10 Home, and all the updates installed, the system starts in just 6 seconds.
by
Add a comment
If it's new it's probably just trying to update. Turn it on, ma!e sure it's co nected to the internet and automatic updates is enabled. Start up windows update and let it go. Check on it from time to time to make sure it's not waiting for you to hit restart. This can sometimes go on for a couple of days.
Add a comment
Add your answer
salisuca will be eternally grateful.
Past 24 Hours: 6
Past 7 Days: 50
Past 30 Days: 274
All Time: 25,636
