Unit records only a couple minutes, then says card full
Records only a couple minutes, with a brand new card, then says card full.
Hi @smokn6string ,
Has it worked OK before using the same capacity card as you are trying to use now?
Has it got the latest firmware installed?
I believe this SD card was ONCE formatted by a different unit than the Video Camera. IF you have a SD card formatted , let say by your computer, even you format it again with the video camera, this card will NOT work on the video camera. It will work for half a minute and indicated NO SPACE, card full. That means the SD card cannot be formatted by anything BESIDES the video camera
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 12
All Time: 223
