2.2, 2.4, 2.5, or 2.6 GHz Core 2 Duo processor
759 Questions View all
megsafe T or L type for MacBook Pro 15" A1226?
The battery for my old MacBook Pro 3,1, 15", A1226 does not charge.
I use the 85W L-type charger. Is there a difference between the megsafe T or L type for it?
I only can use it connected with the megsafe, it always lights up green. Profiler says the battery has only about 140 cycles, but wont charge.
I already cleaned the connections etc.
Add a comment
Here's a good reference: Apple Portables: Troubleshooting MagSafe adapters and see if this is your problem: Portables: L-shaped MagSafe power adapter does not charge computer and LED indicator light does not illuminate
3 Comments:
oh, wow, the article of second link is very interesting, I didnt know that..
I just tried the SMC Firmware but installer says I dont need it, maybe because I'm on 10.6.8 already.
by
I don't know, but is there a difference between the height of the socket ?
There are two models of the Magsafe 85 Watt, the L- and the T-shape.
It seems that the original L-socket sits a tiny bit deeper in the MacBook dock?
Therefore the pins make better contact than the L-form?
http://fs5.directupload.net/images/18051...
by
The connector interface to the socket is the same. As long as you have the same wattage charger they are compatible.
by
Add a comment
The Apple info page shows that only the T-shape is right for the late 2007 A1226 model I guess..
2 Comments:
The listing is what the system came with only! Both can be used.
by
ok, thanks..it is a bit misleading because the L-type is listed for the 2010 and up models..
by
Add a comment
Add your answer
Jamba will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 13
All Time: 491
