Repair guides and support for top and front loading Whirlpool brand washers.
426 Questions View all
Cold water intake hose doesn't seem to be working
Howdy! My hot water hose takes in water but the cold hose doesn't. If I swap the hot water hose over onto the cold tap it will take on the cold water. If I swap the cold water hose onto the hot water tap it won't take on the hot water. Is it just a new cold water hose? I'd be happy just to use the hot water hose on the cold tap (as i never use hot water to wash) but the machine takes on the water, does the first half of the wash, then drains and when it is meant to do the rinse cycle it just stops and pauses there. It sounds like it wants to take on water but it won't - even though it did for the first half of the wash!
I've had the machine for 11 years so it's done me a great service and I love it. Is it all over now?
Add a comment
1 Answer
Chosen Solution
Hi @frankiejean ,
Check the filter located in the end of the hose (the end that goes into the machine) to see if it is blocked at all.
Score 3
8 Comments:
My hot water hose has a washer and filter int the end that attaches to the tap, but my cold water hose doesn't. Is that normal? It must have always been like this because it couldn't have just disappeared!
by
Hi @frankiejean ,
Usually both hoses have the filter in the end.
Turn off the tap connected to the 'cold water hose' and then disconnect the "cold water hose" from the machine and place the end in the laundry tub (or machine tub if no sink available) and then turn on the tap and check the flow from the hose. If it is an old hose sometimes it "collapses' internally blocking the flow.
If the flow is blocked then a new hose should fix the problem.
Just a thought.
by
My top loader let's cold water in but the water runs straight out the hot water hose. Why ???
by
Hi @ michelle tanzillo
What is the model number of the washer?
Not sure what you mean by "the water runs straight out the hot water hose".
Isn't the hot water hose connected to the hot water supply tap (faucet)?
by
I'm testing a HEQS machine out on my outside cold water tap. The water goes in through the cold hose perfectly but it's going straight out the hot water hose .. I've tested other machines outside but this hasn't happened before.. I'm guessing it's got something to do with the inlet valve. Or is it something else. Is it something that I can fix myself ?. If so how ?
by
Show 3 more comments
Add a comment
Add your answer
frankiejean will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 8
Past 30 Days: 30
All Time: 3,458
