The wi-fi only version of Apple's iPad Air, model number A1474. Available in Space Gray or Silver, it packs the custom A7 processor and ships in 16, 32, 64, and 128 GB configurations.
Battery connector doesn't work
I have an iPad Air model A 1475, the battery doesn't charge any more. In the App Store in Argentina they diagnosed it and said the battery was ok, it is the the battery connector that is not working. Do you have a battery connector replacement for this model? Thank you!
Score 1
Add a comment
1 Answer
Chosen Solution
There is no standalone connector on the iPad air unfortunately, the connector is part of a cable directly soldered to the logic board. Unless you can find someone in your area who can do microsoldering, you should replace the board which would probably cost you as much as a second hand tablet. You can try blowing it with a compressed air can and clean it with alcohol and a tiny piece of cloth and tweezers in case it just about some debris and dirt stuck inside.
Score 1
Add a comment
Add your answer
Greta Schormair will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 11
All Time: 381
