Bluetooth on-ear headphones with 40 mm drivers and a 610 mAh battery. Released in 2014.
21 Questions View all
Why aren't my JBL E40BT turning on?
I recently got a pair of JBL E40BT, and today decided to use the BT function. The thing is, it won't work at all. When I plug it in to charge it, it flashes a white light very rapidly, when I take them off the charge and press the BT button, nothing happens. Any idea what I can do?
Score 1
Add a comment
Most Helpful Answer
The white light occurs only while charging and no device can see the headphones then.
Score 1
Add a comment
Hi!
In order to use the Bluetooth function, you need to first pair your device to the headphones; the flashing white light indicates that the headphones are ready and waiting to pair with a Bluetooth-enabled device, like your phone or laptop. This is where you should find instructions on how to set up your headphones.
Add a comment
Did you find the reason ?
I have one of these and not been using for while
When I decided to charge it to start to use again noticed the same behavior
led goes white rapidly flashing while charging, when I remove from the charger, its does nothing
Wonder if is something with the batteries
Add a comment
Add your answer
Lucian Cibotaru will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 11
All Time: 2,755
