The Nintendo DSi is the third iteration in the Nintendo DS line, and made its debut in Japan in late 2008.
263 Questions View all
The sound quit working, what do I do?
The sound on my daughter's DSi quit working, what do i do?
Add a comment
Chosen Solution
Nintendo DSi XL Speakers Replacement
I have replaced the top screen in my childrens ds lite (similar job) several times and have desoldered and resoldered the speakers... It's pretty simple, you don't need anything fancy, just a soldering iron (40w makes the job quicker but you can use lower ) flux, solder, desoldering braid and a steady hand. It may be that you don't need to replace the speakers... It may be a loose solder joint so I'd check first before ordering. You can buy the parts/tools on here.. They are linked on the guide or you can source your own. Good luck
Score 2
Add a comment
But my speakers domt work with headphonew too. Is it the same fix?
Add a comment
Add your answer
Nancy will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 19
All Time: 3,074
