Repair guides and troubleshooting for HP Pavilion dv7 laptops, manufactured by Hewlett-Packard starting in 2008, and featuring a 17.3" diagonal display.
137 Questions View all
What is the rattle sound in the fan.
It sounds like the fan is grinding or rattling. It is coming from the vent that is furthest back on the bottom of the laptop. It is the smallest vent. I have used the compressed air and purchased a cooling stand, but still hear the sound. What's wrong.
Score 1
Add a comment
1 Answer
Chosen Solution
From your description either the bearings are going out on your fan or you need to take the laptop apart and clean out the heat sink. Compressed air will only push things back into the fan. I suggest first you clean out the heat sink and test it to see if the problem is solved. You can find the service manual for dismantling your laptop and accessing your heatsink the at the HP support website, for free and downloadable in the HTML or PDF format. After you clean out your heat sink if the fan is still making noise you will need to replace it.
Score 2
Add a comment
Add your answer
GGK will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 5
All Time: 17,287
