Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
iPhone 6 won't charge even after parts replaced
My iPhone 6 will not charge when connected to power. When plugged in, it does not show the charging icon. It has had the battery replaced, and the charging port flex cable replaced as well. It can still run a phone powered fan though the lightning port, which suggests that the phone can send power through the port still, which remains the question of why it doesn't do the reverse.
Add a comment
Chosen Solution
It is funny that should mention the lightning powered fan, because using this accessory is what caused your iPhone to fail in the first case. I personally love these cheap accessories: they generate money for us by bricking customers’ phones!
Seriously though, stop using that fan immediately and let a microsoldering techinican repair your iPhone 6’s charging circuit. It is possibly Tristar, Tigris, or a line attached to those two.
Score 2
1 Comment:
Thanks for the answer. After a days rest, the phone has decided to charge again! Luckily there was no logic board damage. I have opened up the fan out of curiosity to see what was inside of it, and so it would be rendered unusable. What aspect of the fan damages the phone? Is is a fundamental flaw with the principle of drawing power from the phone, or is it a problem centred just around the fan?
by
Add a comment
Most Helpful Answer
First confirm that your charging cable and brick (hopefully their Apple Original, at least for testing purposes) are fully functional on a known-good device. Ideally, you need to know that your replacement parts are in full working condition. Don't assume that because they're new that they are good. That said, in the absence of a test device, you may have to assume they are in good working condition. If you have access to a USB Ammeter, you could use that to determine if the phone is really drawing current or not.
If the phone still won't take a charge, then the issue is most likely on the logic board and will require a micro-soldering repair.
Score 2
3 Comments:
I have tried multiple cables and bricks, all from apple. I am assuming the flex cable works because it can power a phone powered fan through it, meaning it can send a current through it. It it is a logic board problem, what will need to be replaced?
by
That's what a micro-soldering tech will diagnose. It could be anything involved in the charging circuit. Beware of plz bro solutions :>).
by
Could you please provide all possibilities that could have caused the problem, and every step involved in each possibility?
by
Add a comment
Add your answer
Albert Einstein will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 492
