Released September 16, 2016. Model 1660, 1778 Available as GSM or CDMA / 32, 128 or 256 GB / Rose gold, gold, silver, black, and jet black.
2265 Questions View all
Why isn't my touch screen working after screen replacement?
I cracked my phone a couple weeks ago and got the screen replaced. Since then, I've been having trouble with my touch screen. It won't always register my touch, and sometimes it will move/type/click on something without me touching the screen. Before getting the screen replaced, even after the phone cracked, the touch screen worked perfectly. What could this be, and how can it be fixed?
Add a comment
Did you make sure all ribbons and connectors were firmly in place when you replaced the screen? One possibility could be a loose cable. What you can try doing first is performing a restart a couple of times to see if it calibrates properly. Press and hold down the home button and power button simultaneously until the apple logo appears, then let go. Do this a few times, maybe 3, and see if it helps. If that doesn't help, then another possibility could be that the screen is faulty. If so, have it replaced.
Add a comment
Maybe some screws was mixed and install wrong lead to this issue.
Add a comment
Also this issue was present on iOS 11.3 when using an aftermarket LCD. You can try updating to 11.3.1. Sometimes it can fix this issue.
Add a comment
Add your answer
Bailey Smith will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 11
All Time: 124
