Repair information and guides for the iPhone 8 that was released on September 22, 2017. Model: A1863, A1905
873 Questions View all
iPhone 8 not "showing"a charge after the replacement of LCD?
The LCD was replaced. Now the phone is actually charging but no showing the charge. Everything is working. It shows 1% but it actually is charged. Now, it does power on and off on its own? Left it unplugged for two days. It was charged when I came back to check on the process but still showing 1%. Any thoughts?
Score 1
Add a comment
was the battery disconnected during the repair and reconnected properly post repair?
Add a comment
Same here.. seems to be related to iPhone 8 & IOS 11.3..,
Michelle what iOS are you using? 11.3 perhaps?
Add a comment
If your battery is connected correctly as it should be then its related to IOS 11.3 software issues
Add a comment
Would not be the first problem iphone 8 has with replacement screens on ios 11.3, so could be the ios problem
Add a comment
Hello, i have this problem too... i change lcd for some OEM lcd and not work touch, now i make update 11.3.1 and touch work... but battery is still 0% and not showing the charging bold... when i connect to charger come first few seconds +/- 1100mA, after strarting OS come down on 200-380mA.... i inspect the board and like 2mm from battery connector missing one small part looks like capacitor etc.... i think this is the ptoblem.... can you tell me some good man what is the part? :)
Add a comment
Add your answer
7michele will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 13
All Time: 231
