Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
iPhone 6 won't charge unless turned off
I have one of those braided 10 ft lightning cable chargers. It was working completely fine up until a couple of days ago. Now it only charges the phone when it's off. I tested it with an apple charger and it works fine with that. I thought it was just the charger at first, but wouldn't that only be so if the cable didn't work at all? Please help!
Add a comment
Chosen Solution
If the phone charges fine with an original Apple charger and Lightning cable, then I suspect your braided cable is partially defective and will need to be replaced.
Score 2
Add a comment
Could be your cable yes id certainly be testing with known good chargers to eliminate that first.
May also be a bad tristar IC which will also give you this symptom. Which coincidentally are damaged by using bad chargers
Add a comment
Add your answer
Jennifer Ridgeway will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 3
All Time: 838
