If your iPhone stuck on Apple logo, you should fix it as soon as possible, here is the guide teach you how to fix iPhone 6 stuck on Apple logo without data loss.
Step 1.Download and Run the U.Fone iOS System Recovery
Step 2.Connect your iPhone 6 to the PC
Step 3.Download and Select the Right Version Firmware for your iPhone
Step 4.Begin to download the firmware package
Step 5.Fix your iPhone 6 Stuck on Apple Logo, no data loss at all.
Here is the video guide:
This embed seems invalid. Please check the URL.
You can also Try Recovery Mode to Restore Your iPhone to Factory Settings,but this way will cause data loss
Install the latest iTunes version and launch the program.
Plug your phone using the USB cable to your PC.
While pressing the power key, press the Home button. Hold them together for at least ten seconds until you see the recovery mode screen.
A pop-up screen appears from iTunes stating that there is a problem with the iPhone[your iPhone name] that requires it to be updatetd or restored. Choose update to let iTunes reinstall your iOS system wihout erasing data, if it takes more than 15 minutes, repeat these steps and choose restore instead, which will allow iTunes to erasing your content and settings on the device.
iTunes will reinstall iOS and restore the device to the latest backup. You will however lose data that wasn’t stored in the backup.
