Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
I bent the battery a bit, is it still safe?
Today I replaced the rear housing on my iPhone 6 as the original was bent and badly dented. However, when I took out the battery, both adhesive strips broke immediately, and I had to heat it up with a hair dryer and peel off the battery. But it was very difficult, and the battery got bent near the top. It wasn't bent very far, maybe 20 to30 degrees. When I was done with replacing the housing I bent the battery back into shape and installed new adhesive strips, and it works fine, it charges, holds a charge well, and shows the percentage. The battery was never punctured or torn, just bent. Is it safe to use or should I buy a new one?
Add a comment
Most Helpful Answer
I think it's okay if you don't think it has become bloated or smell anything weird from the battery.
Score 2
Add a comment
no, is not,you should change it
Add a comment
Add your answer
Matthew Sigmond will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 6
All Time: 257
