A collection of guides and support to help with washer repair.
3482 Questions View all
LG front loader won't drain
I have an LG front loader that won't drain. I can hear it buzzing like the drain motor is trying to drain, then I get an "OE" error ("no drain" issue), and it stops without spinning.
So, I removed wet clothes, drained the washer manually and checked the drain filter/trap (it was clear). I then turned on the drain/spin cycle with an empty load and it worked (started spinning).
I put the very wet (soaking) clothes back in, started the drain/spin cycle and I hear the drain motor trying to drain and then get the OE error again and no spinning.
I tried a master reset as described in LG WASHER won't drain or spin. No joy.
Any suggestions on what to try next. Thank you!
Score 1
Add a comment
Chosen Solution
So, I called in the professionals - he said it was a problem with the pump impeller. Cost to fix is $311.
3 Comments:
What is the reason our clothes sour after washing in cold water
by
Do I need a trap on my drain
by
The water sits in the pump and sleeps through into the impellers trapping stagnant water so I would say you need a new pump
by
Add a comment
pump out of my washer
Add a comment
pump out of washer
Add a comment
Add your answer
bocotim will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 15
Past 30 Days: 39
All Time: 14,913
