An E-Cigarette vaporizer is a device used to heat a substance, such as cannabis or tobacco, to a temperature at which it releases a vapor that can be inhaled. It is a reusable alternative to traditional smoking.
121 Questions View all
G Priv 1 wont turn on after update!
I was updating my G Priv 1 and while the update software was installing, the the program went unresponsive and I had to force close it. Now my G Priv won't turn on and my computer won't recognize the usb device. Is the mod totally bricked or is there a way for me to revive it?
Add a comment
1 Answer
Hey David,
Unfortunately, if the device is disconnected while updating firmware/software, it usually bricks the device, unless you would like to lean microsoldering. If you would, I would reccomend watching these videos, or these ones. Also, check out this guide. Sadly, I faced a similar problem with a $50,000 laser engraver. Luckily, it was only $800 dollars to replace some parts, but in your case, I don't know if it will be that easy (but much cheaper!).
Hope this helps,
-Tanner
Add a comment
Add your answer
David will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 4
All Time: 715
