The Alcatel One Touch Idol 3 features a 5.5-inch, 1080 x 1920 display powered by a 1.5 GHz processor. Released in June 2015. Models 6045Y, 6045K, 6045O, 6045I.
103 Questions View all
Why isn't the flip cover settings working anymore?
I don't see the clock anymore in flip cover window after pressing power button. I see the home screen. Also when I open the flip cover screen stays black for so long I tap the screen to get to my home screen. This was working perfectly weeks ago. Settings haven't been touched and flip cover settings is on. Phone is so much slower over all even after boosting. Deleted many apps still way slower. Was great initially but not the same now. Using Evie.
2 Comments
After restarting my phone and disabling some apps it started. Working again.
by
Maybe post that as an answer so this shows up as solved? That way, others with the same problem will find this post.
by
Add a comment
Chosen Solution
Add a comment
Hey Jody,
It sounds like you may have a broken (or blocked) IR proximity sensor. I believe the sensor comes with the display assembly, so it may be as simple as replacing the screen, but I/you will need to check. If it is, check out this guide.
Hope this helps,
-Tanner
Add a comment
Add your answer
Jody will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 7
All Time: 330
