cranks over just doesn't start
Lost power while driving down the road. Have all lights and cranks over just doesn't start
Do you have sparks on the plugs when your crank the engine? Use a spare plug and check on a video something like this https://www.youtube.com/watch?v=mUOmsGii... at 1:50 and see if that gets a spark. Of course you can also purchase a spark tester and do the same thing. Could be a spark issue as well as a no fuel to the injectors (no carb) due to fuel pump etc. Check your fuses to make sure the fuel pump gets power. Your Camry should have a fuel pump relay (EFI main relay see image)
and fuse in the fuse box under the hood. Check there first
Here is the Fuel delivery part of the manual Toyota-EFI.pdf . Start with the section on page 12 and let us know if you need more help with that.
Thanks i will check the fuel
Past 24 Hours: 3
Past 7 Days: 10
Past 30 Days: 35
All Time: 6,590
5 Comments
Won't start hot, if you leave it sit overnight to get cold again will it start? If it does it is a crank angle sensor. Also what year and model is it. What engine size 4 or 6. Auto or manual. What was happened while driving? Were there any other symptoms of hard starting before this happened.
by sm_vulkus
It is a 91 Camry 4cyl auto. I was driving and it just died. No sputtering and dash lights still on. I pulled over and tried to start it but it only cranked over no start. New battery, alt, and starter fusible link is new also. Tried to start again today almost as if fuel isnt getting to carb but has 3/4 tank
by ALANA
So I just found a vacuum line that broke off the part but do not know what the part is or if this is the problem. How do i find this out? It has 2 lines on it and sits near the distributor
by ALANA
@mothelona post some pictures of what you are looking at with your question. Use this guide Adding images to an existing question for that. It will let us see what you see.
by oldturkey03
I'm having the same problem the pump is good just won't turn on when I crank the car I replaced the relay its working but still nothing and the fuses are good to
by Chris Carolus
