The Nintendo 3DS XL 2015, marketed as the New Nintendo 3DS XL, was released October 11, 2014 in Japan and February 13, 2015 in North America.
Power button won't work.
My cat knocked a glass of water onto my 3ds, but very little of it got on the machine itself. I dried it off at the time and turned it off, and when I turned it on again later in the day it was holding the R button by default and the power button would not allow me to turn it off. I took the battery out to cut the power, however since then it would not power on again.
When I plug it in, it turns orange to indicate charging but other than that it does nothing at all. Can not power it back on. I took it apart and there is no evidence of water damage whatsoever, and there wasn't even any moisture in it.
The fact that I couldn't use the power button to turn it off suggested to me that it was a broken power button rather that an issue with the power in general. Suggestions?
Score 1
Add a comment
1 Answer
If you have IPA (90% + preferably) available you can try to clean the connection for the power button, otherwise you can try replacing the power button and/or board it connects to.
Add a comment
Add your answer
Holt Stuart-Hitchcox will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 7
All Time: 744
