Released September 16, 2016. Model 1660, 1778 Available as GSM or CDMA / 32, 128 or 256 GB / Rose gold, gold, silver, black, and jet black.
2264 Questions View all
iPhone 7 Touch ID doesn't work
Hey guys,
I've replaced an iPhone 7 Display (refurbished, original LCD), but after I powered the iPhone on, I couldn't add a fingerprint anymore.
The fault indication (that Touch ID has a failure) does not appear in the homescreen, but appears if I try to add a new fingerprint.
Homebutton (still the original one) and 3D are working without any problems.
Thanks in advance for your help.
Score 1
Add a comment
1 Answer
Most Helpful Answer
Usually it's due to the home button extension cable from the screen being faulty. You'll need to try another screen to confirm that.
Score 2
2 Comments:
Thanks, i tried another display but still no Touch ID. I used 80 degrees to get the glue off. Could it be too much and I damaged the Touch ID?
by
I do the same too. Don't heat up too close, too long and I heat up the glass side then the home button side a bit.
by
Add a comment
Add your answer
Daniel will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 3
All Time: 209
