Repair guides and support for LED, LCD, HD and other Vizio TVs.
931 Questions View all
pls help : vizio tv no picture only sound
Tv model: VIZIO E48U-D0
issue: NO Picture but only Sound present
test performed by me :
1) unplugged and reset by holding power button
2)FLashlight test : still no image
3) after searching a lot I replaced a powerboard : result: still issue persist
4) while back open Iturned on tv and found led light on but no picture at all
Note: there is no seperate t-con board for this model
ther is no danae to any board or capaciters or not even single burnt
NOW I KNOW VIZIO SUCKS BUT PLS HELPPPPPPPPPPPPPPPPP
Add a comment
1 Answer
Chosen Solution
damyansi debana since you already replaced the power board (integrated T-con board) and you made sure that the backlight comes on, the only other thing could be a bad main board (after that it's the panel and there is no replacement for that. You are 100% you have a good power board and you tested all your inputs to make sure that none of them worked.
Score 2
Add a comment
Add your answer
damyansi debana will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 4,793
