Repair guides and support for Kenmore washing machines.
1860 Questions View all
My washer keeps filling with water and won't stop
I have a kenmore washing machine-- it says "series 100" on it. I believe a valve is the culprit but I don't know much about washers. Last time I washed something, it kept filling up with water throughout the entire cycle, even after it stopped. I cut the power (from the fuse box) and it still filled up with water almost to the point of overflowing until I turned the water off from the wall. Help? How to repair it?
Add a comment
1 Answer
Chosen Solution
Martina Villarreal that does sound like a stuck water inlet valve. Unless we can identify your model it will be tough to guide you. Post some images of any tags you may find on the washer as well as of the washer itself with your question. Use this guide Adding images to an existing question for that.
Score 2
Add a comment
Add your answer
Martina Villarreal will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 1,202
