Introduced in September 2004 and replaced with a version in 2010. The following model numbers apply: ZA11S, ZC71S, ZC11S, ZD11S, ZC21S, ZD21S, ZC31S.
17 Questions View all
Why is my ABS and hand brake light on all the time? RESOLVED
Hi guys I would appreciate your help. I have a suzuki swift ZC31.the ABS and hand brake light is on all the time . How do I fix that?
Update (03/12/2018)
Apparently the ABS module had failed.And was swapped out with a junkyard replacement.
Score 3
1 Comment
My breaks ar light weight
by
Add a comment
1 Answer
Most Helpful Answer
I had the same problem. I purchased a used ABS pump from a scrapyard and it solved the problem.
Use your smartphone to photograph the labels and numbers from the failed pump, to ensure that you get the right part.
Score 1
Add a comment
Add your answer
Joseph Fernandez will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 11
All Time: 668
