4-inch iPhone released in March 2016 with similar hardware specifications to the 6S. Available in Silver, Space Grey, Gold, or Rose Gold with 16/32/64/128 GB storage options. Model: A1662 and A1723
1049 Questions View all
Always has "Could Not Activate iPhone" error
As stated above, it's getting this error every time you try activating it, either via local or iTunes activation. Various software resets etc have all been tried. CDMA based unit. Some techs suggested the SIM slot could be damaged. I'm looking for advice what the actual issue is called in the repair world, and if anybody knows a good tech to help with it locally in South Bay Area / San Jose, CA, or via mail order since it's somewhat more involved than a typical phone repair would be.
Score 1
Add a comment
Most Helpful Answer
Use 3UTools and check if the IMEI is being displayed on there. If it is not then the issue is related to the baseband circuit area which can only be fixed by microsoldering.
iPad Rehab should be able to help you out, not sure where they are located in.
Score 3
Add a comment
SOLVED!
I had the same problem just let your phone completely die until it gets to 0% and then charge your phone and then wait for it to turn on and it should be at your normal lock screen again and it should be working fine.
Score 1
Add a comment
Text copy replacement and email are waaaay tooooo smiiiiiiiiiiiiiilllllllllleee
Add a comment
Add your answer
Matthew Hall will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 677
