Guides and repair information for assorted graphics cards, also known as video cards, graphics adapters, or display adapters.
111 Questions View all
Sapphire Radeon RX 570 8GB burned resistor(?)
Trying to understand what is broken here, so I can replace the parts.. believe it says r200 where the part is burned.
Any help is appreciated :)
My card:
http://oi67.tinypic.com/oqkbyo.jpg
rx580 (same pcb):
https://www.techpowerup.com/reviews/Sapp...
Score 1
1 Comment
hmm noone?? :)
by
Add a comment
Most Helpful Answer
Graphics card Schematics Sapphire Radeon RX 570/580 https://drive.google.com/file/d/1ylcnbtS...
B200 = R220
Score 2
1 Comment:
its not the same
by
Add a comment
yes its a resistor with r200 and mr200 written above it but finding the value and package size could be difficult
Score 1
6 Comments:
there seems to be so many different physical sizes for them. and different wattage, etc.
what is the best approach here, do you think?
possible to use different r200s here (with different wattage etc), as long as the physical size fits?
thanks!
by
i would only be guessing as theres no schematic i would probably try 0603
by
most r200 is see are 1w 1% so any resistor around that
by
where i can get that...0603 r200? :)
by
you could probably get them on ebay just type in r200 0603, it will probably not have r200 on the top tho. the thing is how many ohms it will be
by
Show 1 more comment
Add a comment
That is fuse for +12V supply.
If your fuse burn, you must check short circuit before u replace. I have same problem, the fan not have supply voltage. My fuse is good but the circuit no voltage out to fan.
Is any bodyhave a schematic for shapire rx580.? Please help.
Thx Rico
1 Comment:
@hendricorico no, it is not a fuse.
by
Add a comment
@xuw here it is almost 6 years later and I am certain you have replaced your video card by now. Just for completion sake, check the reference designator on the PCB
. It says B200 and MB200, so it is not a resistor. It is a ferrite chip bead inductor. In this case it has a impedance of 220 Ohm 2500mA 25% in a 0603 package
Add a comment
Add your answer
Ole will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 18
Past 30 Days: 50
All Time: 3,506
