Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
Even after replacement, iPhone 6 loudspeaker stops working
So, my iPhone 6 took a swim in the Gulf of Mexico last month.. I had thought the phone was completely dead, but-- miraculously-- after doing a self-repair which initially entailed taking the phone apart, disconnecting the battery, cleaning the internal parts with 99% isopropyl alcohol and then replacing the battery, replacing the charging dock element and finally, replacing the display, I was able to get my iPhone back to normal (almost).
After turning the phone back on, everything worked like it had before EXCEPT the loudspeaker. It vibrated just like it had before, but audio -- when played-- sounded distant and tinny at the very best, and you had to hold your ear up to the loudspeaker to even hear that much.
So, I ordered a replacement speaker kit, opened the phone up again, took out the old one and put in the new one. Closed it up, turned it on and VOILA! The audio came blasting out like new! I was nearly very pleased until I checked the vibration function and got nothing from this new element. To make matters worse, that clear audio coming from the speaker now suddenly crackled off too, and the phone sounded no better than it had with the previous speaker it had inside.
I assumed that the replacement speaker must have been faulty, so I ordered a new one from a different company. When that arrived, I took the phone apart again, replaced the replacement speaker with a re-replacement, closed it up, turned it on and....
....clear audio for about... 30 seconds....and then *CRACKLE CRACKLE*. Back to tinny, faint audio and a very very feint vibration.
What could be causing this? Is there a short happening somewhere in the phone? Is there a bad connection that I should be looking into?
What kind of solutions do I have? I have thought of getting an external case that has speakers built into it, if nothing else, but this still won't give me my vibration function back and it's not an ideal solution.
Any suggestions would be greatly appreciated.
Thanks!
Score 1
Add a comment
1 Answer
Chosen Solution
It sounds like a board level issue relating to the audio circuit on the logic board, board-level repair / micro soldering required.
Score 3
2 Comments:
I was afraid of that.. what about getting a new logic board then? Think the replacement loudspeaker is fried too?
by
You are probably better off buying another phone.
Getting replacement logic boards for apple devices aren't the best idea as you never know if they have issues or not until you try them.
by
Add a comment
Add your answer
Nicholas will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 3
All Time: 57
