4-inch iPhone released in March 2016 with similar hardware specifications to the 6S. Available in Silver, Space Grey, Gold, or Rose Gold with 16/32/64/128 GB storage options. Model: A1662 and A1723
1050 Questions View all
iPhone people can't hear me when on loudspeaker
Hi,
Just had a new ear piece flex cable on my iPhone SE. When I use speaker mode on a call the other person can't hear me, on handset mode it's fine.
Also when I record a video and play it back it's all fuzzy
Is this a problem with the flex cable?
Add a comment
1 Answer
Most Helpful Answer
I assume you meant the front camera assembly, there are two things to check:
- Was the replacement front camera assembly for 5S or for SE? The microphone on these parts are internally different which will not work vice versa if mixed.
- Did you ensure the microphone is seated into the black rubber gasket which sits near the earpiece speaker?
If the microphone was working before the front camera assembly replacement chances are the replacement part is faulty.
Score 1
Add a comment
Add your answer
Jaymie will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 8
All Time: 388
