A smartphone released by Xiaomi in January of 2015. Features a 5.7-inch display and 13MP camera.
25 Questions View all
My battery won't charge, it only shows its charging for 1 second
Hi,
My Xiaomi Mi Max recently stopped charging. It now only stays alive on a charger. It won't charge when its turned off and on the charging even though the charging light is on, on the phone. When the phone is turned on it shows for 1 second its charging but then switches to connect charger even though the charger is connected, and it only stays alive and does not charge. Please help me out guys.
Score 1
1 Comment:
I have the same problem
by
Add a comment
Sounds like your battery is literally dead!
Xiaomi Mi Note Battery Replacement
17 Comments:
I'd say that too but the weird thing is I had this problem like 2 weeks ago as well, and then suddenly it started working again.. :p Any idea why?
by
did you ever drop it in water?
by
No I never did
by
Sometimes when you have your charger plugged in against a bed or something for a long time, the cords can get stretched. You will either have to get a new charger, or try plugging the phone in and leaving it in a specific position.
by
Doesn't work I've tried a lot of different chargers.
by
Show 12 more comments
Add a comment
You need a new charger.
If you try another charger and it doesn't work, your charging panel may need replaced.
6 Comments:
Right but then why did my phone started working after having this problem before?
by
What do you mean you had it before? What happened the first time?
by
Basically the same situation happened but suddenly it started working again and now 2 weeks later I'm back to this issue.
by
Are you able to send a picture of the charging panel? The place on the phone where you put the cable, if you don't already know that.
by
Basically just looking normal man, like a normal charging port.
by
Show 1 more comment
Add a comment
1.use a safety pin and clean the debris from the port
2.open back panel and unscrew bottom part and then clean the pins of usb board
3.replace with a new usdb port panel
Add a comment
my xiaomi device Charge very slow like in 1hour only5 percent charged
Add a comment
Add your answer
Jan Jansen will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 58
All Time: 12,547
