An audio storage device that uses magnetic tape to record and play back audio input.
29 Questions View all
Power board with leaking elco's. Reason of slow starting reel Sony dec
Its a Sony TC 377. Speed is ok but it startsvslow. The 4 Elco's are broken. I will replace them. If the elco's on the power suply are broken what should not work?
Thanks for reply!
Add a comment
1 Answer
Chosen Solution
@tapedecklover that will depend on the power supply and which part of the circuitry is affecting by that. You do need to either give us a complete number of the power supply and/or post some images of the board. Use this guide Adding images to an existing question for that. Yes, slow start can definitely be a sign of bad capacitors.
Score 3
Add a comment
Add your answer
Eibert will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 141
