The Alcatel One Touch Idol 3 features a 5.5-inch, 1080 x 1920 display powered by a 1.5 GHz processor. Released in June 2015. Models 6045Y, 6045K, 6045O, 6045I.
103 Questions View all
All USB options are grayed out. My computer doesn' pop up with options
My computer no longer has options to import/charge etc when plugging a device into the USB ports- All of the USB options are grayed out. Every single thing that refers to the USB is compeltely grayed out. I cant debug and I don't have any "mobile" or "connectivity options". I do not have the device plugged in so that is not the issue either.
4 Comments
Are the internal parts of the usb's damaged?
by
Not that I am aware of but I did have an issue turning my computer on once it was shut down. I had to compress a certain part for it to trigger the connection to even turn on or take a charge. It is fine now. So it is possible.
by
Has it been dropped?
by
No never been dropped or damaged at all.
by
Add a comment
1 Answer
Chosen Solution
Hi,
Things to try and resolve the problem.
1. Start the phone in 'safe mode' and check if the USB options have been restored.
If they have, then a downloaded app is the cause of the problem. The trick is to find out which one.
2. If the above doesn't work try factory restoring the phone.
Make a backup of the phone using the phone's backup feature before using the phone's factory restore feature to reset the phone back to a factory default condition.
Be aware that a factory restore will erase all your data and downloaded apps. It will restore the phone to its' factory default condition. It will be like when you first bought it. That is why it is important to perform a backup first
Once the reset has been completed , check if the USB function has been restored.
If it still doesn't work, there is a hardware fault with the phone.
If the USB function now works, restore the phone, with the backup that you made earlier, using the phone's restore feature.
Check if the USB function now works. If it does then the reset has resolved the problem
Score 2
2 Comments:
I restarted in safe mode but the USB options are still gray
by
Hi,
Did you try the factory reset option at all?
by
Add a comment
Add your answer
Teresa W will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 23
All Time: 382
