Why does my car cut out when I press the gas hard but I let it go it's
I try to pass a car so I hit the gas hard but it bogs out so I let up on the gas it's fine. As long as I press it easy it's fine. It's a 2007 RENDEZVOUS CXL
1 Comment
Thanks I'll try it today
by
Add a comment
1 Answer
Chosen Solution
Probably either a bad fuel pump , bad pressure regulator or a dirty fuel filter. Id start with replacing the fuel filter. Then get a pressure reading on the fuel line and also on the fuel rail if these fluctuate as you rev the car then its a bad regulator if the pressure is low then its a bad pump. Hope this helps
Score 4
Add a comment
Add your answer
Jimmy will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 67
