2.26 or 2.4 GHz / White plastic unibody enclosure
645 Questions View all
Question Closed
Where to buy inverter for MacBook Mid 2010?
My girlfriend spilled some wine on the keyboard and (only) backlight stopped working. Where can I buy the inverter for Macbook A1342 Mid 2010 ?
Thank you in advance for your answers
slavek
Add a comment
Chosen Solution
Macbook Mid 2010 is an LED Backlight screen, it does not contain an inverter. 661-5588 is the Apple part # for the display. If there is a spill inside the machine chances are it could be a problem with the logic board instead of the display. If you connect the machine to an external monitor does it display out to it?
2 Comments:
thanks for the info, I do not have the opportunity to try an external monitor somewhere ( a small village in Switzerland :-| , maybe I can try Interdiscount ) , everything works with a flashlight
by
not everything ... camera is not working
by
Add a comment
I have the same problem, all the symptoms are the same, with a flashlight I can see the screen and occasionally the screen comes on for anything up to an hour before going off. I bought an inverter only to find that it doesn't have one. Is it likely that a replacement LED Backlit screen will fix it or should I do a few more tests before ordering and if so which tests should I do???
Add a comment
Hey, I have the same problem... my backlight stopped working. I have the same Macbook Model A1342. If I connect it to an external monitor it works great,
Is there a way to fix it without changing the complete part?
nelsonmedrano@gmail.com
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 2,131
