New 3DS XL power button light turns on and then turns off.
So, I just got done fixing my 3DS however it appears that It won't power on, it doesn't make any noise, or do anything, the power button goes on for a bit, and then just turns off, the only thing not connected are the speakers (broken ribbon cable connector)
5 Comments
you said you were done fixing it what did you fix?
by ULEES
I fixed the shoulder buttons, however I also took out the motherboard and other things as I was going to replace the broken touchscreen however now I'm not sure. it's assembled at the moment.
by RoastedHotdog
My cousin had the same issue after replacing the battery. The problem was corrected by blowing out all the cable connections and then replacing them.
by M Perrick
"Blowing out all the cable connections" Elaborate please.
by RoastedHotdog
The ribbon cable connector that is soldered to to speakers is what connects the motherboard to the top screen, so that may be your problem. Replace the broken cable.
by Jaden
