The Samsung Galaxy Note 5 (called the Note5) is a phablet-style phone with stylus, manufactured by Samsung, released in August 2015.
271 Questions View all
My phone isn't charging properly.What should I do
Hello everyone!! Okay so everything started 4 days ago when my phone started charging unproperly and it wasnt giving fast charge and when i plug it it gave approx. 8h to fully charge
I thought it was from the UsB cable so i bought a new one and it wasnt the cable so i got it refunded... it was the port
I had the port fixed and everything came back to normal but there's one thing left : my phone is not fast charging with original cable and the original adapter and i want it to be back as it was before everthing happened :p
Thank you for your cooperation I am very thankfull ❤
Add a comment
1 Answer
Most Helpful Answer
Try using a friend's fast charger. The Samsung ones tend to fail over time per my experience.
Score 1
5 Comments:
Well the specialist who repaired my phone had used his fast charger and it worked fine.I don't know why it isn't working anymore
by
If another fast charger worked with your phone, that means your fast charger is the problem. You can find replacements on amazon or other similar sites.
by
I tried a bunch of different fast charging adapters and it didn't work for all of them.I'll try changing the usb cable but if it didn't work what do you think is the issue ?
by
If none of those work, it could be down to a faulty replacement charging port, or motherboard damage.
by
Okay thank you so much ill try everything and ill return to the specialist and report this problem
by
Add a comment
Add your answer
Georges will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 281
