Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
Replacement home button doesn't work
I replaced a iPhone 6 screen & the screen/camera/Speakers are all functional but the home doesn't work at all - nothing. My client came to me with out a home button so I cannot test the original. Is the new button defective or is the software glitching out because it hasn't had a home button in a while.
Score 1
3 Comments
A replacement home button should function the same as a regular home button with one exception-fingerprint ID will not work. As far as glitching? A hard rest should solve the problem. Ensure the replacement is for the six.
by
Im getting no functionality at all - I can't do a hard reset without a home button
by
You can do a hard reset if you turn on Accessibility. It will place a home button on your screen. Then just find the option to restart the phone.
by
Add a comment
Chosen Solution
I would guess the home button to be the defective part.
Score 1
1 Comment:
I will change it out and see. will update. Thank you
by
Add a comment
Most Helpful Answer
Could be homebutton, but could also be the longflex running along the screen
Score 2
4 Comments:
The screen is brand new would that make the new screen defective?
by
its not the actual screen but the metal plate with the ribbon thats attached to the back of the lcd
by
What Daniel said. If it came with the screen, then even higher chance that it does not work as it is likely a cheap part
by
The button was defective - replaced the button (again) and it was fine
by
Add a comment
Touch ID isn’t functional after an screen repair if the home button is replaced.
1 Comment:
I’m not looking to use Touch ID - just use the button for its other functions
by
Add a comment
ensure the cable on the thermal plate is working, try another cable-ensure the socket where the home button is plugged into isn't damaged- try a replacement home button know to work with the iphone six remember the touch id will not work -all other functions should.
Add a comment
Add your answer
jeanise will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 8
All Time: 1,112
