4-inch iPhone released in March 2016 with similar hardware specifications to the 6S. Available in Silver, Space Grey, Gold, or Rose Gold with 16/32/64/128 GB storage options. Model: A1662 and A1723
1049 Questions View all
Blank Screen, Not Recognized by iTunes
I didn't drop it and it hasn't touched water. Just randomly died and I've charged it and I've tried to put it in DFU, Recovery and everything. Still not working, iTunes won't even recognize it.
Score 2
Add a comment
1 Answer
No dough that is the fault of Hardware and causes by U2 ic Because most of the iPhone have damage with such fault because of copy charger or an over charging then need.If you want further info on don`t forget to comment below.
U2 ic is that ic by which charging and power supply from battery will divided.If this ic makes function less then causes dead.
So you have to replace that ic only the solution.
Add a comment
Add your answer
Bella will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 5
All Time: 142
