Repair guides and support for C/K pickup trucks sold by General Motors under the GMC brand, including the GMC Sierra.
77 Questions View all
Turn signal and running lights don't work
Just recently had a new steering column put in and I've been having problems with the lights shortly after. TS do not come on front and rear along with running lights. TS lights do not come on or show on the dashboard when engaging to signal.. any help would be a blessing
Add a comment
1 Answer
Chosen Solution
Fuses. Check which fuse controls these circuits and check if its blown, if it is replace it. If it blows instantly, when you got the steering column replaced, one of the wires got pinched and is shorting to ground. If that isnt the case, whoever put the column in probably damaged a wire or didn't plug a connector in during the process, so if thats the case, you should take it back and have the person take a look.
Score 1
Add a comment
Add your answer
Austen will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 8
All Time: 76
