The Motorola V325 is a clam shell phone, featuring VZ Navigator.
1 Questions View all
Question Closed
Screen Blank, Keys light up.
My V325 has not been used for years. We recently need another phone. We recharged the phone and it starts (keys light up) but the screen is blank. Can it be fixed? Is there a reset button or something?
Add a comment
1 Answer
Chosen Solution
The only thing that i know about the hard reset is to remove the battery and leave it out for a few minutes. To get into test mode do the following: Press CLR then 073887*. Turn on Test Mode and exit the menu back to your normal home screen. Then press CLR and then left softkey to activate FTS (Field Test).
To deactivate FTS and Test Mode, repeat the steps above, and turn Test Mode to off, then exit.
You may also have some LCD problem and may need to replace it. try the reset and take it from there. One step at a time.
Here is the SERVICE manual for you
Hope this helps....
Score 3
Add a comment
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 10
All Time: 649
