Device and repair guides for the 2016 Samsung Galaxy J5 Prime smartphone, model number SM-G570Y or G570.
79 Questions View all
The back and front camera to my phone isn't working,it says camera fai
My front and back camera is not working,i've tried mostly everything as in factor reset, cleared all my caches etc nothing worked.I think the reason it aint working is because of when the back camera got smashed thats when it started to say camera failed but nothings wromg with the fromt camera its perfectly fine but it just randomly stopped working? Help
Add a comment
1 Answer
Hey,
The samsung devices' cameras are usually linked. if something happens to one, it will shut down the App so that you cant use either. Type *#0*#. select front cam, and see if it loads. if it does, then replacing the back camera should fix your issue.
Add a comment
Add your answer
crystal Haddon will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 6
All Time: 127
