Mid 2012 model, A1278 / 2.5 GHz i5 or 2.9 GHz i7 processor.
1624 Questions View all
Screen glitches, computer freezes, & ram must be reseated often
I've resorted to keeping my computer on a pedestal & using a wireless keyboard & mouse, so I never have to touch it except to gently plug the power in. Even so, multiple times a day, I encounter the same scenario: The computer freezes, the screen glitches with what look like a bunch of barcodes, then the telltale 3-beep. After reseating the ram, everything works fine, if a little slow. What once happened every few days, now occurs 3-5 times a day. I've searched online for replacement logic boards, but the ones that show up with my criteria don't look like the one in my computer. Thoughts?
4 Comments
Are the barcodes pink and go from top to the bottom of the screen or are they white and go from left to right of the screen?
by
Hi, @jennessee had you tested your memory yet?
Try using apple diagnostic to test the hardware
by
@salmonjapan I replaced the memory, which seems to be a temporary fix. The problem doesn't happen as often. After a little more poking around, I have discovered that the top ram slot doesn't hold securely. It looks like I will need to replace the logic board after all.
by
Add a comment
1 Answer
Chosen Solution
Try testing your memory. If it comes back fine, you may need a new board. If not, I would consider finding the faulty stick(s) and replace them and see if it works. Good luck!
EDIT: Use Apple Memory Diagnostic
Add a comment
Add your answer
Jennessee Rosenberg will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 1,963
