An expansive variety of repair guides for electronic gear, ranging from home and car audio to calculators.
26479 Questions View all
Burnt PCB component on desktop LED-lamp, repairable or not?
Hi!
Got a fairly unused desktop lamp from my father which, according to him, only needed a new AC-adapter. Went and got a new one this morning but when i plugged it in it still didn't work. Noticed som odd stains on top of the lamp, looked like it came from toothpaste, which had run down and in where the on and off switch is located. Decided to open it up to see if that was the reason for the problem. It turned out that the stain had run inside and on to the circuit board frying on of the components.
My question is if this is repairable, i guess it's always is, but is it worth it? And is this fairly easy to do on my own?
I've got some soldering skills from before, even if it's been a few years since last time.
I started searching to see if there where spare parts, like a new PCB, but it doesn't seem to exist. Sure i could buy a new lamp but a new one goes for about 350$, and my father got it for free from his old job and then handed the problem over to me.
I'm hoping for an "easy" fix but not sure if that's possible.
It would be great if anyone had an idea to how i can fix it :)
Below is an image of the burnt component.
I tried searching for the numbers online but can't find anything similar.
2 Comments
You will need new chip
by
Yeah, that much i understand. What I'm thinking about is that if it's doable on my own, and if so, where can i obtain a new chip. As i mentioned above, I've tried looking for a new one online but with no luck.
by
Add a comment
Chosen Solution
In short, Yes it would be rather easy. All you need is a soldering iron with a fine tip, some solder with flux, and some solder wick to remove it and a pair of tweezers.
One thing I do recommend is to use 99% or 91% isopropyl alcohol and a toothbrush to clean the residue off the board. That way you can see if there is any more damage.
As for where to get the chip, I'm not sure. I hope someone else can guide you.
And since you know how to solder, it's easy. Put some new solder on each of the pins, hold the solder wick on top of the pins and hold the iron on top of the wick and wait for it to suck up the solder. Then move to the next one. Once all solder has been removed, the chip should come off. Then you pul solder on one of the corner pins, like the chip up and melt that one point to hold the chip, then just put solder on all the other pins and it should work. I also recommend getting 2 chips just in case you mess up. The chips should only be a few cents once you find one.
If i was at all confusing or you have any questions, please ask and ill clear things up for you!
Score 2
10 Comments:
Great! Thanks for your answer, it was really helpful!
Kind of what i was looking for :) Thought that it would be a fairly easy fix but thought I'd ask around here for some pro-tips.
Really appreciate the walkthrough, doesn't seem to complicated, just need to take it slow.
All i need to do now though is to figure out where to find a new chip.
by
Might've found what I'm looking for, or at least that it is. My best guess is that it's the LED-driver that has burnt. I'm not 100% sure but I've been searching for the numbers on the chip and with the 3404 I stumbled upon something called LED Driver IC SO-8. The chip is located next to the on/off button which is to the right on the picture so it kind of feels like I'm on the right track.
by
No problem man, this is kind of what im good at. As for the chip, it does sound like your on the right track, good luck with your search! Also ebay or mouser or digi-key are probably the best places to purchase the chip once you found it.
by
Could you also give me the make a model of lamp and a more zoomed out picture of the board with the broken chip circled?
by
The model is a Luxo Ovelo, think they are made by a company named Glamox. I'll add a zoomed out picture up in the original post.
by
Show 5 more comments
Add a comment
did you ever fix it? I can’t quite find the chip either:
http://how-to.wikia.com/wiki/How_to_iden...
but using your 3404 clue, i’d agree that it’s probably a dc/dc step-down from Analog or TI:
http://www.analog.com/media/en/technical...
http://www.ti.com/general/docs/lit/getli...
Add a comment
Add your answer
Jacob Silfverlin will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 15
All Time: 228
