iMac Intel 27" EMC 2309 (Late 2009, Core 2 Duo 3.06 or 3.33 GHz) ID iMac10,1, EMC 2374 (Late 2009, Core i5 2.66 GHz or Core i7 2.8 GHz) ID iMac11,1
ODD Temp Sensor Cable & AHT
Update - unfortunately need further advice...
After having replaced the missing temp sensor cable with the OWC-solution as recommended, I still have to deal with fan(s) running at full speed. Unbelievable, but I noticed another missing cable! The "ODD temp" connector socket is empty. I then removed all connectors and took out the complete logicboard, hoping to find a loose cable behind it, but: no!
As I wasn't sure what to do next, I first of all got myself the app "TG pro" and took a photo of some of the info provided. I hope someone will thus be able to guide me on my way of fixing my good old one. Thanks for your attention,
Ulli
NB: I also wanted to try the AHT - but neither pressing D nor ALT-D while booting works- I can't find my installation disk anymore and haven't found a download link yet either...
Update (12/03/2017)
HI Dan,
I can't add a screnshot in a comment, can I? At least, that's why I'm posting an answer...
Do you have an idea, how I can get hold of the "Apple Hardware Test"?
1 Comment
You'll need the original grey disks that came with your system, or create a bootable drive and download the AHT from Apples web site. I don't think it will help you here TG Pro did ID the failed sensor as the LCD.
by
Add a comment
1 Answer
Chosen Solution
Well, Thats a good mystery!
The ODD sensor is the sensor thats mounted on the optical drive case. Review this IFIXIT guide: iMac Intel 27" EMC 2309 and 2374 Optical Drive Replacement. Jump the Steps 11 & 17 which its connected to the logic board and the sensor its self. The sensor cable Optical Temp Sensor - Apple P/N 922-9229
If the Optical drive fan is defective follow this IFIXIT guide: iMac Intel 27" EMC 2309 and 2374 Optical Drive Fan Replacement and this is the part: Optical Fan - Apple P/N 922-9150
Update (12/03/2017)
I think I see what happened here! You forgot to plug the LCD sensor back in. Review this IFIXIT guide: iMac Intel 27" EMC 2309 and 2374 Display Replacement jump down to Step8 is it plugged in?
iMac Intel 27" EMC 2309 and 2374 Display Image
Guide
Difficulty:
Moderate
30 minutes - 1 hour
iMac Intel 27" EMC 2309 and 2374 Optical Drive Image
Guide
Difficulty:
Difficult
45 minutes - 2 hours
iMac Intel 27" EMC 2309 and 2374 Optical Drive Fan Image
Guide
Difficulty:
Moderate
2 Comments:
Dan, thanks for hanging on. Checked the cable, felt plugged in properly. The issue, I guess, is the missing ODD-cable which I'm going to order now. There are even some remains of the glue sticking on the optical drive case...
I just can't believe it - what a f... computer shop I gave my iMac to for an initial graphics card repair. I sent an email to the owner and complained about the missing HDD temp sensor cable two weeks ago and he couldn't even be bothered to reply. Paying about $ 75 just for two missing cables which had been there before is quite a nuisance...
by
Problem solved! It was the missing ODD temp cable, "Good old one" is running perfectly now and ready for the Bay - thanks again to you, Dan, and to "JDW" for enouraging to try my own repair.
by
Add a comment
Add your answer
Apfelgarten will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 12
Past 30 Days: 25
All Time: 2,503
